Problem with dotnet mapping after connect to LibreOffice
LO Version: 25.8.0.0.alpha0+ (X86_64) / LibreOffice Community
OS: Ubuntu 22.04
Greetings.
I built LibreOffice from source to be able to access the .NET bridge added last summer.
This bridge provides 2 methods in the Bootstrap class: bootstrap and defaultBootstrap_InitialComponentContext, which are also available in some other bridges.
The first method creates its own LibreOffice process, connects to it via a pipe and returns an XComponentContext, from which you can get XDesktop2 and XComponentLoader for further work with documents. This one working fine.
The second method creates a local XComponentContext with which you can connect to a remote LibreOffice process using a pipe or socket. This also working fine but then you need to get the remote XComponentContext, which is where the problem arises.
Following the logic from the Java and C++ code examples, I can correctly get the remote XComponentContext, but then when trying to get XDesktop2, an exception is thrown with the message:
could not map given type name com.sun.star.frame.XDesktop2 at /home/username/libregit/core/bridges/source/net_uno/net_base.cxx:230:
at com.sun.star.uno.native.NetEnvironment.ThrowError(String pWhere, String pMessage)
Both processes start with environment variables set. Is this a problem with the bridge implementation or are there some additional conditions that need to be met?
I tried different strategies to get the remote XComponentContext but they all lead to the same result, here is one of them:
var unoUrl = "uno:socket,host=localhost,port=2083;urp;StarOffice.ServiceManager";
var localComponentContext = NativeBootstrap.defaultBootstrap_InitialComponentContext();
var urlResolver = UnoUrlResolver.create(localComponentContext);
var resolvedObject = urlResolver.resolve(unoUrl)
    ?? throw new UnoWrapperException("Provided initial object name unknown at server side");
var defaultServerContext = resolvedObject.query<XPropertySet>()
                                         .getPropertyValue("DefaultContext")
                                         .cast<XComponentContext>();
var desktop = Desktop.create(componentContext);
var componentLoader = desktop.query<XComponentLoader>();
All goes good until Desktop.create(componentContext) line
Additional:
I am not very familiar with the LibreOffice source code, but after looking at the core/net_ure/source/bootstrap/bootstrap.cxx file, I assumed that the problem might be that the received remote XComponentContext is not mapped to .NET.
So I added a method to the .NET Bootstrap bridge source code that internally receives the remote XComponentContext, maps it to .NET and returns it in this form. But this also did not give any results. The code for this method:
 SAL_DLLPUBLIC_EXPORT IntPtr bootstrapFromUrl(const sal_Unicode* unoUrl,
                                            const Context aContext)
    try
        OUString sConnectionString(unoUrl);
        Reference< XComponentContext > xContext;
        Reference< XComponentContext > xLocalContext(::cppu::defaultBootstrap_InitialComponentContext());
        // create a URL resolver
        Reference< bridge::XUnoUrlResolver > xUrlResolver(
            bridge::UnoUrlResolver::create( xLocalContext ) );
        // connect to office
        xContext.set(
            xUrlResolver->resolve( sConnectionString ), UNO_QUERY_THROW );
        // Get a mapping between the C++ and .NET environments
        Environment cpp_env(CPPU_CURRENT_LANGUAGE_BINDING_NAME);
        Environment net_env(u"" UNO_LB_NET ""_ustr, new Context(aContext));
        Mapping mapping(cpp_env.get(), net_env.get());
        if (!mapping.is())
            Reference<lang::XComponent> xComp(xContext, UNO_QUERY);
            if (xComp.is())
                xComp->dispose();
            throw RuntimeException(u"could not get mapping between C++ and .NET"_ustr);
        // Map the XComponentContext to a .NET proxy
        return mapping.mapInterface(xContext.get(), cppu::UnoType<decltype(xContext)>::get());
    catch (const Exception& exc)
        SAL_WARN("net", ".NET bootstrap error: " << exc.Message);
        aContext.throwError((u"" SAL_WHERE ""_ustr).getStr(), exc.Message.getStr());
        return nullptr;
I would assume, that any problem with the ~new dotnet bridge implementation in LO should by default be considered likely bugs. Please file it, and hopefully you will either get the explanation, or it would be confirmed and eventually fixed.
I planned to submit a bug report later if it turns out that it’s not my ignorance of the connection process. Thank you
Bug was filed and can be found at: 166857 – Mapping exception in new .NET bridge
Thanks.
But what does the very first “1. Create a new .net 8 application” step there? In which IDE (if you use it), or using which tools / steps? What language should be used (I suspect C#)? Basically, I can’t see how can I start reproducing from scratch. Maybe providing a sample project ready to be tested (either as an attachment there, or on github or the like) could help.
More detailed information on reproduction is provided in the bug comment.
It is difficult to provide a self-contained repro, due to the need to use a builded LibreOffice with the “–with-dotnet=yes” option and its SDK files.
Hmm, so you built LibreOffice yourself, but used the SDK from distro? I am not sure, that this is going to work. Why not build SDK yourself?
Both LibreOffice and SDK are used from the same build that i did myself.
Additional information about the bug has been added to the bug page in Bugzilla.
A workaround has been found that should help with identifying the error.
I saw your post about compiling LibreOffice with --with-dotnet=yes. That’s exactly what I’ve been looking for!
Could you please share the LibreOffice.Bindings..nupkg file with me? I would be very grateful.
Thanks in advance!
