Dear friends,
I am currently working on converting a DOCX / ODT into EPUB format. I learned that it is a very good method to use Styles rather than making linebreaks and other formating manually when you are making an EPUB. So I have been pursuing this without much problems until the time came to make the endnotes section.
For some reason there is no apparent way to create any heading saying “ENDNOTES”. If I try to make a heading according to the ordinary method I did throughout the document, ie. applying Styles and using one of the saved layouts and put this at the very end of the document, then when I try to create an endnote in the main text, the first note would automatically generate a pagebreak and end up on the page after the intended heading. And this is despite the fact that the settings for the heading style in question does not have any pagebreak in its settings. And I can’t find it in the settings for foot- and endnotes, even if I thought it was easily available there…
I would be very grateful for any kind support.
Specifics:
LO version: 24.2.3.2 (X86_64) / LibreOffice Community
OS: Windows 10.0 Build 19045;
19045.4291
22H2
Conversion: Calibre - From DOCX / ODT to EPUB
