Hi.
Since version 6.1.6, I have noticed that radio buttons no longer work in PDF forms. Since I create quite a few PDF forms, I have had to revert to the last version this this feature seems to have worked properly, that being 6.1.6. Has anyone else had this problem with later versions of LO?
See tdf#127217
I am seeing differing result in Mint 19.3 & Ubuntu 18.04 depending upon the viewer. Okular sort of shows the selected button but a few other viewers only show a weak dotted square outline when selected. Currently on LO v6.4.0.3
This was happening to me on version 6.2+. I just downloaded version 7.0.0 to see if this issue has been resolved.
No need to download to check. Just check bug link to see if resolved. BTW it is not.
As from reported in the bug above mentioned:
I still have this problem with Writer under Linux:
Version: 7.6.4.1 (X86_64) / LibreOffice Community
Build ID: 60(Build:1)
CPU threads: 8; OS: Linux 5.15; UI render: default; VCL: gtk3
Locale: it-IT (it_IT.UTF-8); UI: it-IT
Ubuntu package version: 4:7.6.4-0ubuntu0.20.04.1~lo2
Depending on the reader (Xreader vs. Okular) I can flag radio buttons or not.
In particular with Xreader I can’t, but if I export in PDF the same document (ODT) from Windows then I’m able to flag them, even in Xreader.
Hi, i had the same problem i was struggling with for almost a week. The solution (at least for me) was to use File->Export As->Export as PDF and check ‘Archival (PDF/A, ISO 19005)’ in the export settings table. The pdf version doesn’t matter.
From that moment on, the PDF was radio buttons also checkable in Linux’s Evince and Atril. In Xpdf it NOT works.
Try it and let know if it helps.
