Right click context menu = not like MS
Hello
I did the normal download install of the Libre Office most recent.
I did read about a fix so the right click can allow for a menu like MS-I need a rt click so the rt click context menu I think it is called, >word Doc.
I am not fgood enought to perform the fix or its not working.
I am ony fair with windows and know not much about Linux or it would be easier.
Thank you for offering an alternative to M$ and all the wwork you do.
Peter
I hope I can finda reply as I am unfamiliar with getting around the forum.
I assume that you have chosen the tabbed interface, in which case you probably can’t see the menu, the the top leftmost icon with tooltip Menubar to see the menu. Any steps given here will use the menu
MenuBarInTabbedInterface
You can modify the context menu in Tools > Customise but it would require a lot of work and it still won’t look like Word’s context menu. Remember that Word’s context menu is so crowded because they removed basic functions from the toolbars and threw away the menu. Maybe consider using the Standard interface in LibreOffice. See the Writer Guide for more information, English documentation | LibreOffice Documentation - LibreOffice User Guides
Consider if the Sidebar offers sufficient options for formatting. Click View > Sidebar to toggle visibility.
