ho ancorato l’immagine ed ho fatto la copia delle singole colonne, ma niente, l’immagine non viene riportata
sub CopiaSelezioneColonne
rem define variables
dim document as object
dim dispatcher as object
rem get access to the document
document = ThisComponent.CurrentController.Frame
dispatcher.executeDispatch(document, ".uno:Copy", "", 0, Array())
dim args2(1) as new com.sun.star.beans.PropertyValue
args2(0).Name = "Name"
args2(0).Value = "Foglio22"
args2(1).Name = "Index"
args2(1).Value = 4
dispatcher.executeDispatch(document, ".uno:Insert", "", 0, args2())
dim args3(5) as new com.sun.star.beans.PropertyValue
args3(0).Name = "Flags"
args3(0).Value = "SVDT"
args3(1).Name = "FormulaCommand"
args3(1).Value = 0
args3(2).Name = "SkipEmptyCells"
args3(2).Value = false
args3(3).Name = "Transpose"
args3(3).Value = false
args3(4).Name = "AsLink"
args3(4).Value = false
args3(5).Name = "MoveMode"
args3(5).Value = 4
dispatcher.executeDispatch(document, ".uno:InsertContents", "", 0, args3())
end sub
Mentre questo è facendo la copia di tutto il foglio cliccando sul primo quadratino in alto a sinistra
sub Main
dim args3(1) as new com.sun.star.beans.PropertyValue
args3(0).Name = "Name"
args3(0).Value = "Foglio22"
args3(1).Name = "Index"
args3(1).Value = 4
dispatcher.executeDispatch(document, ".uno:Insert", "", 0, args3())
dim args4(5) as new com.sun.star.beans.PropertyValue
args4(0).Name = "Flags"
args4(0).Value = "SVDT"
args4(1).Name = "FormulaCommand"
args4(1).Value = 0
args4(2).Name = "SkipEmptyCells"
args4(2).Value = false
args4(3).Name = "Transpose"
args4(3).Value = false
args4(4).Name = "AsLink"
args4(4).Value = false
args4(5).Name = "MoveMode"
args4(5).Value = 4
dispatcher.executeDispatch(document, ".uno:InsertContents", "", 0, args4())
end sub
Mentre questo è con il comando seleziona tutto
sub Main
dispatcher.executeDispatch(document, ".uno:SelectAll", "", 0, Array())
args3(1).Value = 4
args4(1).Value = 0
args4(5).Value = 4
end sub
