SQLite connection with Libreoffice Base error
Ubuntu 16.04
Libreoffice Base ver. 5.1.6.2
DB Browser 3.11.99
While connecting Base with SQLite click on Test Connection this error shown
“[unixODBC][Driver Manager] Data Source name not found, and no default driver specified”.
I setup odbcinst.ini and .odbc.ini and declare the database in a file .odbc.ini I don’t
understand why this error.
Can you please help and thank you
Don’t have much experience with SQLite (doesn’t have many capabilities I need) but will offer what I can.
Please see the links I have posted in my comment here (first comment under question) → Cannot create or read records in a SQLite over ODBC database?.
Also, my use is with 64-bit Lo. You do not specify your bitness and may be a factor.
