When printing more than a single label is there an option to indicate to the printer where it should print the first label (similar to when printing a single label)?
I am not aware of a process to indicate where a single is to be printed (type in at specific label?). Please provide this information.
As for multiple, this is the only method I have seen thus far → Labels start offset for partially used label sheets
Thank you for your reply.
If you start Write>Labels there is an Options tab that allows you to specify the start position BUT ONLY FOR A SINGLE LABEL. I cannot understand why the designer/programmer only limited this important feature to a single label.
