System requirements for previous releases?
Where can I find the system requirements for previous LO releases?
For the current release of LO, the system requirements page shows Linux kernel version 4.18 or higher and glibc2 version 2.27 or higher. My system (debian, 4.9 and 2.28) doesn’t meet the kernel requirement.
https://wiki.documentfoundation.org/Documentation/System_Requirements#Windows,_Mac,_Linux,_and_Android is intended for that, but it doesn’t go into details for Linux. Maybe @cloph and @ilmari can help.
Thanks, I’m guessing it is not readily available.
I grabbed some install tarballs
If the READMEs are to believed, the sysreqs in 24.2 25.2 25.8 are all the same:
  • Linux Kernel version 3.10 or higher;
  • glibc2 version 2.17 or higher;
  • FreeType version 2.8.0 or higher;
  • GTK version 3.20 or higher;
It’s not until 26.2 do the README sysreqs change:
  • Linux Kernel version 4.18 or higher;
  • glibc2 version 2.27 or higher;
  • GTK version 3.24 and ATK version 2.36 or higher;
Regarding System Requirements | LibreOffice - Free and private office suite - Based on OpenOffice - Compatible with Microsoft I simplified it a bit - it used to say that kernel 4.18 or higher and glibc2 version 2.27 or higher are since 24.2. The next iteration of the website will have a git history for the content.
Debian 9 is EOL since 2022, though, but you could get kernel 4.19 from backports.
Yes, I’m way over due for fresh install of Debian.
I’m off topic here … what other changes would I need to make on my debian system if I backported the kernel?
I’d probably be happy with 25.8. Is the README is correct and complete about the system requirements?
No idea, I don’t run Debian myself. Off the top of my head, I can’t think of anything that would break with a 4.x kernel upgrade.
Based on what you quoted, the readme is not correct - we forgot to update it in time.
There is also a dependency for nss.
fwiw, I backported the kernel to 4.19. This maxed out me root directory. But I could boot to 4.19. I grabbed the latest LO, which had a dependency for nss which my system did not meet.
also fwiw, I’m in the process of upgrading my system to a fresh install of latest stable debian, 13 something or another. So this thread, for my purposes, is done. Thanks for your help.
