The Groupedbar works on 7.1.7.2 using Big Sur, but every single update since has broken it.
Check out this page first First steps to take before submitting a bug - The Document Foundation Wiki
Then how to submit a bug report if those checks don’t solve the issue, How to Report Bugs in LibreOffice - The Document Foundation Wiki
Is this true, no matter which icon theme you use?
I only use the standard toolbar, as the other ones have always had some issue or other on macOS, so switched back to the default.
Yeah it’s broken on all the fonts.
I guess I’ll be staying with 7.1.7.2 for longer
Just updated to 7.5 and grouped bar is still broken
I’ve deleted the user profile- makes no difference, back to 7.1.7.2 for me
What is happening with the bug report I said you should make? Cheers, Al
