Hi.
I’ve a problem with chapter numbering. it is not possible to use dash instead of dot between level numbers as separator. for example how to create a multi-level list like:
1-
1-1-
1-2-
1-2-1-
1-2-2-
2-
2-1-
2-1-1-
2-1-2-
Apparently, the dot separator is hard-coded within Writer. I found no workaround based on List Styles (the sequence number formattor) to force this separator to anything else.
Thanks. I’d tried in vain to tackle the problem in some way!
See this bug report
Bug 67986 - EDITING: FORMATTING: Choose characters of each SEPARATOR between numbers in Outline Numbering
Thanks for the information. I hope the problem be fixed.
