I have just downloaded LibreOffice to be able to use the database application. It asked me to download Java which I did. Overtime I try to use the database program it still asks be to download and states no java installation can be found. Can anyone tell me please what I am doing wrong. I was sure this program would work with an Apple computer but perhaps not.
Ciao, look at this link: Download Java for OS X 2017-001
If my answer helped you, vote it with
and with ∧ (here on the left)
Thank you for your suggestion. Unfortunately I have tried this and for some reason it does not work. To be frank I am stuck. Perhaps a good nights rest might help and I will try again tomorrow. Thanks again for trying to help I appreciate it.
I am in the same boat. I need to install Java OSX 2015.01? Can’t find it. Am offered 2014, it won’t install because a newer version is installed. I forsee needing to spend fifteen minutes swapping Javas each time I need to run Base. Yikes! Has anyone discovered a way through? Thank you!!!
Because LibreOffice offers a database application similar to Access and the fact that you can’t run access on a MAC made me think this would be a good solution for me. However the problem with Base and it continuing to ask for Java has made me think again - which would be a pity. Can’t anyone help overcome this problem. I have downloaded Java several times now when told the program won’t work without it. Surely there must be a solution to this problem. Anyone’s help would be much appreciated.
Is there a way to “bump” this, to try to attract someone to answer?
JG
LO | get-help | System Requirements | macOS
Due to an issue, there are the following restrictions with Java: on macOS 10.10 and newer, JRE isn’t found, JDK is required
TDK | wiki | FAQ | General | macOS
On macOS 10.10 and newer, please note that you need to install JDK, not JRE. You may find download links choosing JDK version on this page. On macOS 10.09, neither JRE, nor JDK are found. LibreOffice releases available from Apple App Store don’t include Java support at all, because apps distributed in the App Store are not allowed to depend on optional functionality like Java.
If this helps then please tick the answer (
…and/or show you like it with an uptick (∧)
