See the following image.
Maybe I need an update?
Thank you!
Until now it works in safe mode.
Nothing changed; the problem is still here.
If it works in Safe Mode but not in normal mode then there is probably corruption in your user profile. I would use the manual method to reset the profile thus retaining a backup and being able to restore most of the folders afterwards.
[Edit]
If you are on Windows, click Tools > Options > LibreOffice > View and tick the box Force Skia software rendering. Allow LibreOffice to restart.
Maybe neither you nor LibreOffice.
You don’t tell the OS you use. On Win10 I have seen sometimes windows not refreshing completely (icons below the cursor do).
As a work-around I minimize the window and open/maximize it again. This causes a full refresh.
My OS is Linux Lubuntu. I will try your method.
thank you
It works even for me.
