ive created this macro to delete cells in columns B to N and rows 2 to 999, but when I try to run it it gives that error – any tips on how to fix it?
(Edit: activated screenshot -AK)
Your attached code is a VBA command. The (MS Excel VBA) and the (LO StarBasic + LO API) are not compatible.
The LO can run some VBA codes, but not all of them. The Excel can not run any LO API commands.
You must use the compatibility directives if you want to use VBA codes in the LO.
But it is better to rewrite your macros based on the API and one of the supported programming languages.
API: Application Programming Interface.
Sub my_delete
Dim oActiveSheet As Object
Dim oCellRangeByName As Object
Rem Get Active Sheet
oActiveSheet = ThisComponent.getCurrentController().getActiveSheet()
Rem Get Cell Range
oCellRangeByName = oActiveSheet.getCellRangeByName("B2:N999")
Rem Clear wanted contents - 1 = clear values - see links
oCellRangeByName.clearContents(1)
End sub
For clearing contents, see:
XSheetOperation Interface Reference
and
Thanks for reply, I ran that but nothing happened https://gfycat.com/VainMindlessJohndory I’m trying to get it to delete all the text you can see in that sheet (except the very top pinned row)
Nothing happened because the macro is set to clear values and the remarks noted. The answer also pointed to other values for clearContents such as 4 for Strings which it appears you have.
Try with the different value.
Please note, values can be combined for deleting multiple types such as:
oCellRangeByName.clearContents(5)
will clear Values and Strings.
