Where:
A1:A100 is a range of values, and
B1:B100 is a range of either “x” or “”
I want to sum values in A1:A100 for cells with empty strings “”, so:
=SUMIF(B1:B100;"";A1:A100)
Problem: it sums no values; the answer is 0, regardless of what is in B1:B100.
Yet, this method works fine in Excel (I know, OpenOffice is not Excel), and this method works fine in formulae that test only one cell. For example: in C1 the formula =B1="" will produce TRUE. Ditto for =IF(B1="";“TRUE”;“FALSE”)
So, why does an empty string work in a single test, but not for a range?
