The command beep generates a machine-specific warning sound (on the Mac a dull and unimpressive thud). But is there any other mechanism which can be used in a macro to generate different alarm sounds, such as sound(pitch,length) ?
Under linux, but I also believe under other operating systems this works.
Instead of a generic sound, this functon use any mp3, also very short, of any kind
function playMp3(sFullPath)    ' sFullPath = path-name-extension
     dim oPlayer1 as object, sUrlSound as string, oSounMgr as object
     sUrlSound = ConvertToUrl(sFullPath)
     If not fileexists(sUrlSound) Then
         msgbox sUrlSound & " does not exist",16
     else
        If GetGuiType() = 1 Then
            oSounMgr = CreateUnoService("com.sun.star.media.Manager_DirectX")
        Else
            oSounMgr = CreateUnoService("com.sun.star.comp.media.Manager_GStreamer")
        End If
        If IsNull(oSounMgr) Then
           msgbox "Sound Mgr not set",16
        else
            oPlayer1 = oSounMgr.createPlayer(sUrlSound)
            oPlayer1.setMediaTime(0.0): oPlayer1.setVolumeDB(-10)
            oPlayer1.setPlayBackLoop( 0 ): oPlayer1.start(0)
            while oPlayer1.isplaying()
               doevents
            wend
            oPlayer1 = nothing:  oSounMgr = nothing:
        End If
     End If
End functionThank you. It may come to that, and I have found a convenient site for creating a short sine-wave signal: [Custom Sine Tones | Audio Test File Generator].
However, since it involves using an external file, not integral to the database, I am a little doubtful of its utility.
