Problem with hidden sections [closed]
asked 2013-01-21 11:41:31 +0200
jenthe_m gravatar image
updated 2013-06-15 00:02:17 +0200
manj_k gravatar image
I'm using a template to generate a pdf-document with the LibreOffice Java api. In this template there are some user fields which are filled in java-code. Also I want to use sections to hide text if it's not applicable.
Here's the problem. For testing all the sections had the hide condition: ' 65OrGreater EQ "0" '. But the last section in my template is NOT hidden while all the other sections ARE hidden.
I know it's a strange question but I hope it is clear.
Closed for the following reason question is not relevant or outdated by qubit
close date 2013-04-28 20:08:22.172875
I do not know enough about the API to answer, but your question really makes me curious. Generally, what are the functions used to apply sections automatically to certain parts of a document?
CyanCG gravatar imageCyanCG ( 2013-01-23 19:56:39 +0200 )edit
You can file a bug with the template attached. This doesn't look like a common misuse.
Zhang Weiwu gravatar imageZhang Weiwu ( 2015-12-28 12:57:28 +0200 )edit
