I’m using a template to generate a pdf-document with the LibreOffice Java api. In this template there are some user fields which are filled in java-code. Also I want to use sections to hide text if it’s not applicable.
Here’s the problem. For testing all the sections had the hide condition: ’ 65OrGreater EQ “0” '. But the last section in my template is NOT hidden while all the other sections ARE hidden.
I know it’s a strange question but I hope it is clear.
