Calculate difference between two cells - Part 2
asked 2017-08-29 20:37:28 +0200
this post is marked as community wiki
This post is a wiki. Anyone with karma >75 is welcome to improve it.
I'm doing a mileage spreadsheet for my car,
In cell A1 heading = Mileage
in cell A2 value = 50000
In cell A3 value = 50100
In cell A4 value = 50200
..and so on
Difference amount goes into Cell B2
So in this case B2 = 200 (A4-A2)
Without knowing how many entries will be introduced in column A (could be 10 or could be 110 entries) How can I ask calc to calculate the difference between the last entry in Column A and the first Entry in Column A (A2)
So Basically I just want to subtract the first entry from the last current entry In Column A with out out knowing how many entries there might be using an array formula.
Thanks again for the help
I can't see that your post is a wiki. Sorry.
Please name the cells like A1; A2 and so on; it's a convention
Grantler gravatar imageGrantler ( 2017-08-29 22:29:49 +0200 )edit
1 Answer
answered 2017-08-29 22:13:56 +0200
updated 2017-09-02 08:58:24 +0200
So you need the MAXimum of column A. Alter the formula this way:
Write in B2 the following formula: =MAX(A:A)-A2
Tested on LO 5.4.0.3 - be aware that =MAX(A:A) does not work in some previous versions or Apache OpenOffice.
Cheers
Login/Signup to Answer
1 follower
Asked: 2017-08-29 20:37:28 +0200
Seen: 1,289 times
Last updated: Sep 02 '17
