Problems with tables in Writer 6.0.2.1
asked 2018-04-08 18:48:33 +0200
Megue gravatar image
As you can see in the picture, the text in the second table (Key Contents) is not adjusted to the table. I do not know how to adjust it!
Thanks!
image description
1 Answer
3
answered 2018-04-08 18:56:04 +0200
You have the paragraph's right indent wrong. Put the cursor into the cell, and use Format-Paragraph-Indents and Spacings tab, and change the "After text". Or maybe simply reset manual formatting using Ctrl+M.
Thanks a lot!
Megue gravatar imageMegue ( 2018-04-08 19:16:00 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2018-04-08 18:48:33 +0200
Seen: 105 times
Last updated: Apr 08 '18
