As you can see in the picture, the text in the second table (Key Contents) is not adjusted to the table. I do not know how to adjust it!
Thanks!
Thanks!
You have the paragraph’s right indent wrong. Put the cursor into the cell, and use Format-Paragraph-Indents and Spacings tab, and change the “After text”. Or maybe simply reset manual formatting using Ctrl+M.
Thanks a lot!
