must impress odp and audio files be in same folder?
asked 2018-06-23 23:42:34 +0200
this post is marked as community wiki
This post is a wiki. Anyone with karma >75 is welcome to improve it.
Latest Impress. Windows 10. .WAV files have been added using Transition panel. Audio
wav file was added as link or as embedded?
kompilainenn gravatar imagekompilainenn ( 2018-06-24 16:16:09 +0200 )edit
Sorry, just seeing your question. Using Slide Transition, I add sound from a file. So, I would say this is NOT a link, but embedded. Additional experience suggests the .wav file and Impress presentation file should be in the same folder, when sound is added, and remain there.
I have a possibly related question, but will mark this one as answered. Thank you.
rsw1941 gravatar imagersw1941 ( 2018-07-08 19:50:34 +0200 )edit
1 Answer
answered 2018-07-08 19:54:17 +0200
Answered: it appears Impress will follow the full path for the sound. I infer from this that the presentation file and sound file should remain in their respective folders. IF you plan to share or move the presentation to a new folder, THEN first put the sound and presentation files in the same folder, AND re-connect the sound files using Slide Transition.
-OR- Is the audio actually embedded within the Impress file?
rsw1941 gravatar imagersw1941 ( 2018-07-09 18:56:47 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2018-06-23 23:42:34 +0200
Seen: 44 times
Last updated: Jul 08 '18
