why wont an envelope print when the first element is a graphic ?
asked 2018-06-25 01:40:59 +0200
fw7oaks gravatar image
Printing an envelope with a graphic in the top lefthand corner doesn't work, it used to before updating to Version: 6.0.4.2 (x64)
Perhaps I should add that my troubles are on a Win10 based machine, the print preview works OK, but only when printing with an HP LaserJet 2420 PS do I get no output if the first element is a graphic. Printing on an HP Color LaserJet CP1510 works OK.
Do I have a Windows, HP or LibreOffice problem ?
Thanks for you help since it spurred me into trying to find another solution
fw
fw7oaks gravatar imagefw7oaks ( 2018-06-26 16:41:47 +0200 )edit
1 Answer
answered 2018-06-25 03:21:40 +0200
Ratslinger gravatar image
updated 2018-06-25 03:25:14 +0200
Don't see the problem. Tried with different graphics (sample is PDF output - print to file):
image description
image description
Done on Linux Mint 18.3 with LO v6.0.4.2
Login/Signup to Answer
1 follower
Asked: 2018-06-25 01:40:59 +0200
Seen: 15 times
Last updated: Jun 25 '18
