I am using MacBook Pro running El Capitan. How should I upgrade LO, which URL is best to use? [closed]
asked 2018-09-03 00:11:32 +0200
KDan gravatar image
updated 2020-08-18 16:48:10 +0200
Alex Kemp gravatar image
I'm not a tech expert, so please give fully detailed info. Am I supposed to QUIT all LibreOffice documents before I begin the update?
close date 2020-08-18 16:48:33.868285
Yes, when performing an update, all documents should be closed.
ebot gravatar imageebot ( 2018-09-04 12:19:50 +0200 )edit
1 Answer
answered 2018-09-03 12:04:58 +0200
ebot gravatar image
Downlaod here: https://www.libreoffice.org/
Installation Instructions here: https://www.libreoffice.org/get-help/...
Hi ebot, The installation instructions page you noted for help doesn't say anything about how to proceed when using a Mac, and I don't want to make a mistake, so some additional guidance would really be appreciated. Also, is it important to quit out of LO before doing the upgrade? Thanks for your help.
KDan gravatar imageKDan ( 2018-09-04 12:10:03 +0200 )edit
Sorry, I myself use Win-10 and can not help specifically to the Mac, unfortunately. Maybe another user can help you with a Mac system. Alternatively, you can also sign up on the users mailing list and put your question there again concretely. I wish you success. Mailing lists: https://www.libreoffice.org/get-help/...
ebot gravatar imageebot ( 2018-09-04 12:17:45 +0200 )edit
1 follower
Asked: 2018-09-03 00:11:32 +0200
Seen: 65 times
Last updated: Sep 03 '18
