I’m not a tech expert, so please give fully detailed info.
Am I supposed to QUIT all LibreOffice documents before I begin the update?
Yes, when performing an update, all documents should be closed.
Downlaod here: https://www.libreoffice.org/
Installation Instructions here: Installation Instructions | LibreOffice - Free Office Suite - Based on OpenOffice - Compatible with Microsoft
Hi ebot, The installation instructions page you noted for help doesn’t say anything about how to proceed when using a Mac, and I don’t want to make a mistake, so some additional guidance would really be appreciated. Also, is it important to quit out of LO before doing the upgrade? Thanks for your help.
Sorry, I myself use Win-10 and can not help specifically to the Mac, unfortunately. Maybe another user can help you with a Mac system.
Alternatively, you can also sign up on the users mailing list and put your question there again concretely. I wish you success.
Mailing lists: Mailing Lists | LibreOffice - Free Office Suite - Based on OpenOffice - Compatible with Microsoft
