Problem with printing selected cells in Calc
asked 2018-09-26 15:57:59 +0100
tim.uk gravatar image
I have a selection of cells in a spreadsheet. The selection is 3 columns wide, and 46 rows deep - it will easily fit on one page of paper. However when I print the selected cells, only the first 17 rows x 3 columns are printed. What am I missing?
1
answered 2018-09-28 07:02:34 +0100
Emoh gravatar image
Please check it out again if Print Preview displaying the selected cells correctly; there shouldn't be any problem.
You can try select the desired range and then from Menu -> Format -> Print Range -> Define
print document.
Print preview does not show all the selected cells either :( It should not be necessary to define a print range. However I have determined that the bug seems to be related to the page breaks - if the selection crosses a page break, only cells up to the page break are printed. I've submitted a bug report with an example.
tim.uk gravatar imagetim.uk ( 2018-09-28 11:01:02 +0100 )edit
answered 2019-04-05 21:44:23 +0100
jelabarre59 gravatar image
It would be handy if "print preview" would allow you to do a preview on just the highlighter/selected cells. Currently you would have to print highlighted cells and print them, hoping they're readable or fit on the page properly. Usually when you're printing a highlighted group it's because you need a "quick and dirty" output, and so you shouldn't have to print and fudge multiple times to get something usable.
answered 2019-04-06 00:03:01 +0100
m.a.riosv gravatar image
In the tab [Sheet] of the page style, you can set up on the Scale, a percent, or how the print range should fit in a number of selected pages.
Login/Signup to Answer
1 follower
Asked: 2018-09-26 15:57:59 +0100
Seen: 828 times
Last updated: Apr 06 '19
