JRE problems with Mac
asked 2018-11-09 21:01:24 +0200
Gib gravatar image
When I tried to access one of my LibreOffice databases today I got the message that the JRE could not be found or is corrupted. The JRE was there but I reinstalled my JRE (Java 8 update 191, Build 1.8.0_191-b62) and restarted my computer which didn't help. I'm running MacOS 10.13.6. I have been using my database with no problems so this kind of came out of the blue. Any solutions?
1 Answer
answered 2018-11-10 06:27:52 +0200
Ratslinger gravatar image
Mac needs JDK installed. Please see this post -> on firefox and have loaded java 32
Does the JDK file replace or augment a JRE file? The JRE8 191 is present on my Mac but LO can't seem to find it. In LO preferences/advanced the JRE files box is not populated. When I think about it, I believe my problem started after an OS update. FYI my LO version is 6.0.6.2.
Gib gravatar imageGib ( 2018-11-10 19:57:31 +0200 )edit
JRE is actually part of JDK. As to why you need JDK, please see my answer here -> Still can't find Java installation and the link within it.
Ratslinger gravatar imageRatslinger ( 2018-11-10 20:01:19 +0200 )edit
I downloaded JDK today. I did have to go to LO preferences/advanced where the JRE window was now populated and then chose the JRE. Then I could open my Base database with no problems. Did not require a restart. Thanks.
Gib gravatar imageGib ( 2018-11-15 17:35:18 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2018-11-09 21:01:24 +0200
Seen: 45 times
Last updated: Nov 10 '18
