[WRITER] cant put second frame below first frame. [closed]
asked 2019-04-09 11:48:04 +0200
slawalata gravatar image
Hi,
I have 2 frame, I want the 1st frame one on top and the 2nd is below/under (not back)..
but the second frame is always overlap the first frame, i cant drag and move it down.
box 2 overlaps box1.
boths have archor to paragraph.
how to move 2nd frame down ?
Closed for the following reason the question is answered, right answer was accepted by slawalata
close date 2019-04-15 05:03:39.547514
Have you created two paragraphs so that each frame can be linked to its own paragraph? If you have only one paragraph the frames will overlap.
petermau gravatar imagepetermau ( 2019-04-09 14:14:43 +0200 )edit
(LO 6.2.2.2 on LinuxMint 18.2-64 Mate)
@slawalata - I can not confirm your statement. After inserting the frames I could move them without any problems. Only one (empty) paragraph for anchoring. Which LO version are you working on?
Grantler gravatar imageGrantler ( 2019-04-09 16:35:06 +0200 )edit
Hi,
@Grantler, sorry for late replay...
i use LibreOffice 6.2.2.2
Version: 6.2.2.2
Build ID: 2b840030fec2aae0fd2658d8d4f9548af4e3518d
CPU threads: 8; OS: Mac OS X 10.13.6; UI render: default; VCL: osx;
Locale: en-ID (en_ID.UTF-8); UI-Language: en-US
Calc: threaded+
What i found that i can move first frame but still cant move the second frame...
@petermau, thx you, but still it doesn't work for me.. i put in frame1 -> paragrahph1 and frame2-> paragraph2 but still i cant move second frame.
lg, slawalata
slawalata gravatar imageslawalata ( 2019-04-15 04:48:36 +0200 )edit
I got it friends ;)
I set a wrong value in. It was Frame Properties -> Height -> AutoSize. And it had 100% ;(
I change to Relative To -> Paragraph area, and Height 100% (not related i think) and WOLA i can move second frame freely :D
Many thanks in @Grantler and @petermau.... your support level ups my confident to move 100% to libreoffice..
fg,
slawalata
slawalata gravatar imageslawalata ( 2019-04-15 05:02:26 +0200 )edit
