Hi,
I have 2 frame, I want the 1st frame one on top and the 2nd is below/under (not back)…
but the second frame is always overlap the first frame, i cant drag and move it down.
.boths have archor to paragraph.
how to move 2nd frame down ?
Hi,
Have you created two paragraphs so that each frame can be linked to its own paragraph? If you have only one paragraph the frames will overlap.
(LO 6.2.2.2 on LinuxMint 18.2-64 Mate)
@slawalata - I can not confirm your statement. After inserting the frames I could move them without any problems. Only one (empty) paragraph for anchoring. Which LO version are you working on?
Hi,
@grantler, sorry for late replay…
i use LibreOffice 6.2.2.2
Version: 6.2.2.2
Build ID: 2b840030fec2aae0fd2658d8d4f9548af4e3518d
CPU threads: 8; OS: Mac OS X 10.13.6; UI render: default; VCL: osx;
Locale: en-ID (en_ID.UTF-8); UI-Language: en-US
Calc: threaded+
What i found that i can move first frame but still cant move the second frame…
@petermau, thx you, but still it doesn’t work for me… i put in frame1 → paragrahph1 and frame2-> paragraph2 but still i cant move second frame.
lg,
slawalata
I got it friends
I set a wrong value in. It was Frame Properties → Height → AutoSize. And it had 100% ;(
I change to Relative To → Paragraph area, and Height 100% (not related i think) and WOLA i can move second frame freely
Many thanks in @Grantler and @Petermau… your support level ups my confident to move 100% to libreoffice…
fg,
slawalata
