How to use Greater Than and Less Than to Prevent or Allow Equations
asked 2019-07-03 11:21:01 +0200
CSTIG gravatar image
I'll do my best to explain what I mean.
=IF(H3>H4,H3-H4) This formula works as intended and lets me easily subtract the values in H3 and H4.
The issue is if I add, IF(H3<H4,H3-H4) I still need the values to subtract, but I don't want the values to go below 5 or into the negatives.
So I'm not sure how to set a minimum, I assume it is MIN(), but then I'm not certain on how to set up multiple functions together since my previous attempts to do so didn't work too well.
2
If H3<=H4, it's known that H3-H4 is 0 or negative.
Your total function should be simply
=MAX(H3-H4;5)
Mike Kaganski gravatar imageMike Kaganski ( 2019-07-03 11:42:11 +0200 )edit
Hi @Mike IMHO why not put answers as Answer, it lets to mark them as correct, it's how Ask works, I think.
m.a.riosv gravatar imagem.a.riosv ( 2019-07-03 22:33:29 +0200 )edit
@m.a.riosv: well - I didn't directly answered the asked question ("How to use Greater Than and Less Than") :-)
Mike Kaganski gravatar imageMike Kaganski ( 2019-07-03 22:35:06 +0200 )edit
I think it's not only a matter of solving directly the question, but to give the questioners a way to get it solved, or where to search for a solution. But show them how to do it, alternatives, not a solution as a gift.
m.a.riosv gravatar imagem.a.riosv ( 2019-07-03 22:44:12 +0200 )edit
1 Answer
answered 2019-07-03 16:09:50 +0200
Thank you, @Mike Kaganski. Just using =MAX gives me what I need, instead of trying to use > or <.
Please use the comments or edit your question.
m.a.riosv gravatar imagem.a.riosv ( 2019-07-03 22:30:58 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2019-07-03 11:21:01 +0200
Seen: 934 times
Last updated: Jul 03 '19
