considering base as front end to multi users data driven application
asked 2020-03-09 05:27:36 +0200
jeblesh gravatar image
at my work we use LibreOffice and files for documentation we attempted to use wide spread local ERP software but its cumbersum and implemented horribly for our needs
i m considering building a database application and honestly the main factor of choosing a front end will be how easily i can manage to build and maintain the forms/front end my experience in developing is in magic (about 15 years ego) and base seem more similar to what am used to so am attempting to avoid learning web development for this project
use case, all data should be stored on local server it needs a user system any update to the data be audited user+date and time+previous data should be log`d
i can solve the user management system and logging on the server side but base have options to manage that itself and save me the time ? also i guess this is pretty common use case so i will love to hear about any solutions other then me actually building it from scratch ...
1 Answer
answered 2020-03-09 10:30:06 +0200
ikopanas gravatar image
I am not sure if this helps... If not please ignore...
Recently we implemented a local MySQL Server with Base front end. Everything seems to work fine. It is quick and multiuser also.
We did not really care to have a user system as to audit updates but this should be implemented into the initial database schema on the server side I suppose. I don' t think that base (as front end) could manage something like that.
I d like to hear about your trial and the results!
thanks its good to know of other project's working properly in multi user application so how is the user's implementation work's in your project? users have database unique login to MySQL server or sum other way to login? or the multi users are in the aspect of multi machines working on the same database using a single login account?
jeblesh gravatar imagejeblesh ( 2020-03-11 07:13:01 +0200 )edit
Login/Signup to Answer
2 followers
Asked: 2020-03-09 05:27:36 +0200
Seen: 34 times
Last updated: Mar 09
