writer outline - is it possible to view different numbers of outline levels for different parts of a long document?
asked 2020-04-04 01:36:57 +0200
AditiMezzo gravatar image
Before going through the learning curve on new software i would like to make sure it has the one most important feature for me. With Word 6 way back when, i kept track of an entire 300 page dissertation in a single document — by expanding and contracting how many outline levels would be visible, for any size segment. I still pine for that feature.
1 Answer
answered 2020-04-04 08:04:57 +0200
ajlittoz gravatar image
LO Writer window is split between a main pane for document content and a side pane called Navigator. The Navigator lists all objects of the document. One category is Headings. You can develop it to show all level-1 paragraph headings. You can then develop independently one of them to show its level-2 headings, and so on.
Thus the answer to your question is yes.
When you double-click on one of the headings in the Navigator, the cursor in the main pane jumps to the corresponding heading. There is a side-effect, however: this closes or develops the clicked navigator heading (because double-click is an alternate way of expanding/shrinking to the left-side triangle).
To show the community your question has been answered, click the ✓ next to the correct answer, and "upvote" by clicking on the ^ arrow of any helpful answers. These are the mechanisms for communicating the quality of the Q&A on this site. Thanks!
Login/Signup to Answer
1 follower
Asked: 2020-04-04 01:36:57 +0200
Seen: 24 times
Last updated: Apr 04
