1
View Problem
asked 2020-09-20 14:21:34 +0200
Indiassist gravatar image
In LO Impress Version 7. 0.1.2 regarding the view of the sidebar (under the spanner icon – in view menu is set Normal and Sidebar) Properties > Slide : these properties are partly hidden, covered by the Layouts tab. How to get rid of this Layouts tab in order to have full view on the slide properties ?
What are you missing from the properties? Can you upload a screenshot? To do so, edit your initial question and use the Paper clip symbol.
ebot gravatar imageebot ( 2020-09-20 16:01:45 +0200 )edit
1 Answer
answered 2020-09-20 16:01:13 +0200
ebot gravatar image
You cannot get rid of them, but you can hide them. Click on the small arrow to the left of the word "Layout".
image description
With me Windows 10 Home; Version 2004; 64-Bit | LibreOffice, Version: 7.0.1.2 (x64).
ebot gravatar imageebot ( 2020-09-20 16:02:37 +0200 )edit
Thanks , but that dosn't help. I can not find an option to upload a screenshot. The button Masteransicht is missing. The lowest I see is the checkbox Master-Objekte - on my system Master Objects.
Indiassist gravatar imageIndiassist ( 2020-09-20 16:32:32 +0200 )edit
@Indiassist, I had the same problem with the button, which was not missing, but simply very badly positioned/hidden, to a point i have to say this could be classified as a bug. Take a look here, and i think you'll see. The red circle indicates just the upper edge of the button, which toggels the master view
image description My LO version is 7.1.0 ... so it could be a version related problem with the button, maybe?
igorlius gravatar imageigorlius ( 2020-09-20 20:11:03 +0200 )edit
Exactly - I have the same view. Well, if needed it is possible to click the edge of that button and now I know by the other screenshot from ebot there is obviously nothing more behind it. Thanks everybody :)
Indiassist gravatar imageIndiassist ( 2020-09-21 07:41:32 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2020-09-20 14:21:34 +0200
Seen: 63 times
Last updated: Sep 20 '20
