7.0 Calc - Split a cell Diagonally and write text in each parts horizontal aligned left and right - SOLVED
asked 2020-10-06 10:32:09 +0100
artofit gravatar image
updated 2020-10-07 10:54:03 +0100
I wish to do in LibreCalc as :
https://www.youtube.com/watch?v=EVRm0...
However, I do not manage to have a top text to the right and a bottom text to the left, when I use aligment it does for the all cells.
Maybe I do a stupid thing, but neither can I with: https://chenyhsu.github.io/blog-beta/...
Thanks
@artofit, The second link in the question is an example of a table made in a text document (Writer in our case).
LeroyG gravatar imageLeroyG ( 2020-10-06 16:54:50 +0100 )edit
3
answered 2020-10-06 13:12:26 +0100
updated 2020-10-06 16:48:57 +0100
  • Type a space (in light red in the second image) and the first line word, Ctrl+Enter, type the second line word, Enter. (Edit: I just changed the order of the first two lines).
Choose menu Format - Cells…:
  • In Borders tab, on the User-defined: field, select the descending diagonal.
image description
  • In Alignment tab, and for Horizontal alignment select Distributed, OK.
image description
Made with LibreOffice 6.3.6.2 (x86); OS: Windows 6.1.
Add Answer is reserved for solutions.
Press edit below your question if you want to add more information; also can comment an answer.
Check the mark (Correct answer mark) to the left of the answer that solves your question.
answered 2020-10-07 10:53:37 +0100
Thanks for solving: LO 7.0, Linux
@artofit, I'm glad it worked.
Your thanks is not an answer to your question. Please, repost it as a comment. To do that, hover on "more" (just above these lines), and press "repost as comment under question", or paste it as a comment to the answer. Thanks.
Don't forget to check the mark (Correct answer mark) to the left of the answer to show that your question was solved. Thanks in advance.
LeroyG gravatar imageLeroyG ( 2020-10-07 14:43:29 +0100 )edit
Login/Signup to Answer
1 follower
Asked: 2020-10-06 10:32:09 +0100
Seen: 101 times
Last updated: Oct 07
