How should I insert QR code in Writer
asked 2020-10-11 16:18:54 +0200
chris-of-dorking gravatar image
I am using LO 6.4.6.2 One of the new things in LO 6 is supposed to be the ability to insert QR code in a Writer (or any other) document. I tried insert > object but there is no QR option, only OLE object, formula and chart. I see that it can be done in Draw, but not in Writer. Is there something I need to do first?
Which operating system do you use and from where did you install (package repository)? I got native version 6.4.6.2 RPM packages (Linux) from TDF (libreoffice.org) and Writer shows Insert -> Object -> QR Code...
Please try to run LibreOffice in Safe Mode (Help -> Restart in Safe Mode) and check the availability of menu Insert -> Object -> QR Code...
Opaque gravatar imageOpaque ( 2020-10-11 17:06:59 +0200 )edit
I'm using Ubuntu 20.04.1 My installation of LO was updated when I upgraded the operating system from 18.04 I tried restarting LO in safe mode and opened a Writer document and sure enough, Insert -> Object -> QR Code was there, and I tried it and it worked. Obviously the potential is there, but when I opened it normally again the QR Code option wasn't there in Writer.
chris-of-dorking gravatar imagechris-of-dorking ( 2020-10-11 17:55:50 +0200 )edit
Sorted! Since safe mode disables user configurations i thought I should look at those, so I used Tools -> Customise -> Menus and there was the option to insert QR Code in the Insert Object sub-menu. Thanks, guys.
chris-of-dorking gravatar imagechris-of-dorking ( 2020-10-11 18:11:10 +0200 )edit
I have LibreOffice 7.0.1.2 (64) on Windows 10 Build 19041. I just successfully added a QR code to Calc.
silverfox210 gravatar imagesilverfox210 ( 2020-10-11 18:37:10 +0200 )edit
Just successfully entered QR code in Writer & Draw as well. Good Luck.
silverfox210 gravatar imagesilverfox210 ( 2020-10-11 18:41:39 +0200 )edit
answered 2020-10-11 18:43:18 +0200
according to your Safe Mode test - reset you user profile using the following procedure:
To reset the user profile perform:
  • Start LibreOffice
  • Start in Safe Mode using Help -> Restart in Safe Mode and confirm the restart using button: Restart
  • Archive your profile expanding Advanced (click on the word Advanced right above Help button) and click Archive User Profile button
  • Select option Reset to factory settings
  • Activate [x] Reset entire user profile
  • Click button Apply Changes and Restart
Hope that helps.
answered 2020-10-11 18:12:48 +0200
Open Tools -> Customise -> Menus and add QR Code to the Insert Object sub-menu.
answered 2020-10-11 17:05:38 +0200
Zizi64 gravatar image
The feature is present (and it works) in my LO 6.4.6 portable version on Win10
QR
Login/Signup to Answer
1 follower
Asked: 2020-10-11 16:18:54 +0200
Seen: 76 times
Last updated: Oct 11 '20
