How do I get rid of a view with side by side pages?
My Libre Office suddenly started opening a new document with side by side pages. How did that happen? How to get it back? It is set to have only 1 column.
Windows 10 is updated.
Please to conform with site “style”, make your question short (a catch phrase). The description part is unlimited in length. This is where you can be verbose.
Do that with the edit link both in the title and the description.
I also suspect your question is Writer related. You tagged common, meaning you add the problem also in Calc, Impress, Draw, Base and Math. So please retag writer instead of common if I’m right.
You are correct. I am a total novice at this forum. And I am requesting help with Writer.
My writer opens a ‘new document’ with p.1 on the top right of the page but then puts a p.2 below and to the left of that [automatically]. Then p.3 is placed under p.1 to the right of p.2. Very confusing and no idea how I set it to do this. And as I commented, I have insured that it is set as a 1 column document.
You added a comment instead of modifying your question and title. Please retry.
There is no forum here. It is a questions-and-answers site. Read these guidelines and ask good questions.
Look at your status bar, near the right-hand end. Do you see 5 page symbols? A single page, two pages side-by-side, and two pages in book fashion? Click on the single page. That should do it.
Sorry, but I already tried that but no help.
ve3oat,
One of my docs that actually worked. The other side-by-side doc, pushed all content to the left column (page), but kept the side-by-side display with all 2nd (right-hand) pages being blank.
Why such inconsistancies?
TBNK
Can’t tell without the document. Please attach it. There is likely some strange configuration in it, or perhaps it is saved as .doc(x) and the conversion process did not understand some formatting.
Reread @ve3oat’s answer. The bottom right area of the window looks like this:
zoom slider
If you don’t see these tools, View>Status Bar.
Click on one of the 3 page symbols, from left to right: single page, multiples pages, book view.
