change default settings for pasting images
Is there a method to change the default settings for pasting an image? We regularly cut and paste numerous images in a document. We add text to the right or below the image so want it anchored properly. This is what we have to do in Libre Writer:
1. After pasting the image into a Writer doc:
2. Right click on image
3. Choose ‘Properties’
4. Choose ‘Type’
5. Under Position/horizontal choose ‘Left’
6. Under “Anchor” choose "To Paragraph"
7. Select 'Wrap' tab
8. Under ‘Settings’ select Wrap
9. Change to ‘After’
Now the image is aligned left and you can add text to the right or below. We do this all day.
That’s nine steps for every image we add to the document!!! There is no way to change the default.
Try Version 7.1.0.3 >>> https://www.libreoffice.org/download/...
Choose Menu
Tools>Options>LibreOffice Writer>Formatsettings there at Picture (or Image?)>Anchor
Furthermore, the positioning of the image depends on the style / frame template "Images".
