LibreOffice Writer Index issue [closed]
asked 2014-10-27 08:11:25 +0200
Ankita gravatar image
Hi,
I'm facing an issue with the index/table of contents generation in the document.
I am inserting a document index using the "Insert Index/Table" command from the menu options. However, when I close the document, reopen it, and update the index- the hyperlinks do not work. Also, the index levels collapse and only the main headings (Heading1) remain.
I tried regenerating the index afresh, but it doesn't work. Can you please help?
close date 2016-03-05 18:31:46.096683
To help you more information is needed. Please have a look at http://ask.libreoffice.org/en/questio... and provide especially information on which steps you took to insert the which index.
ROSt52 gravatar imageROSt52 ( 2014-10-28 06:10:56 +0200 )edit
1 Answer
answered 2014-10-28 12:59:08 +0200
Thanks for the link. I will try to elaborate the issue. I am creating a Software Requirement document using Libre Office Writer version 4.2.
I want a table of content in the following format:
  • 1 INTRODUCTION 4
  • 1.1 Purpose 4
  • 1.2 Scope 4
  • 2 SYSTEM OVERVIEW 6
  • 3 DETAILED SYSTEM DESIGN 8
  • 3.1 Design description 9
I click Insert, go to "Insert Index/Table" from the menu option and apply formatting to the individual Levels. For example, for Level 1, the index Structure is LS LS E# E T. Similarly for Level 2 and Level 3.
Once I click OK, the index is generated and I save and close the document. However, when I reopen the document and click Update Index, the table of content looks like:
  • 1 INTRODUCTION 4
  • 3 SYSTEM DESIGN 7
The second level index and the hyperlink is removed. I think some where, the LibreWriter resets the index properties on reopening the document.
1 follower
Asked: 2014-10-27 08:11:25 +0200
Seen: 362 times
Last updated: Oct 28 '14
