Is there a problem with sorting a text or spreadship entries v 4.2.8.2? [closed]
asked 2015-04-22 05:37:46 +0100
this post is marked as community wiki
This post is a wiki. Anyone with karma >75 is welcome to improve it.
Hi, When I try to sort entries of either a spreadsheet or a text document it doesn't work. I select the area to be sorted and then specify the column. Result, no change in sequence. This is occurring with OS X Yosemite and Libreoffice 4.2.8.2. Thanks Bob DeBellis
close date 2020-08-20 16:39:09.672457
What exactly are you doing and what is the result of each step?
Please help the helper to help you!
ROSt52 gravatar imageROSt52 ( 2015-04-22 09:55:32 +0100 )edit
