Help me solve lag between slides?
asked 2016-05-03 05:09:48 +0200
BurningGlove gravatar image
I use MS power point slides from my company for presentations. I load them into LibreOffice 5 but there is a lag between each slide. How can I fit that?
1 Answer
answered 2016-05-03 08:37:00 +0200
pierre-yves samyn gravatar image
Hi
If by lag you mean time (if not not, could you specify the problem?), this can be adapted in the Slide Transition panel of the Sidebar:
  • Select the slides in the Slide pane on the left
  • Display the Slide Transition panel in the Sidebar
  • Select the speed in the Modify Transition list
Regards
Login/Signup to Answer
1 follower
Asked: 2016-05-03 05:09:48 +0200
Seen: 426 times
Last updated: May 03 '16
