I use MS power point slides from my company for presentations. I load them into LibreOffice 5 but there is a lag between each slide. How can I fit that?
Hi
If by lag you mean time (if not not, could you specify the problem?), this can be adapted in the Slide Transition panel of the Sidebar:
- Select the slides in the Slide pane on the left
- Display the Slide Transitionpanel in the Sidebar
- Select the speed in the Modify Transitionlist
Regards
