How to resolve Copy/paste problem?
asked 2016-08-31 14:50:58 +0200
romanokun gravatar image
Hello. It seems that there is a bug in both last Still and Fresh version.
It is simple as that: sometimes when I try to paste something into Writer document it put the previous material from the clipboard, not the last one. So I need to save the document, close it, reopen it, put "Paste" and only in this case it will paste the correct last piece of the clipboard.
Annoying thing.
Has anyone encountered with the same problem? How to fix it?
To developers: please investigate into this and if it is a real bug than
Roman
What version of LibreOffice/operating system are you using?
Zeca gravatar imageZeca ( 2016-08-31 14:55:54 +0200 )edit
I have tried both versions Fresh (LibreOffice_5.2.0_Win_x64) and Still (LibreOffice_5.1.5_Win_x64). I am using WIndows 10 64bit
romanokun gravatar imageromanokun ( 2016-08-31 15:10:34 +0200 )edit
I note that this bug has already been reported Bug 101257. But the status was needmoreinfo. I added some more information just now and changed it too "Unconfirmed"
romanokun gravatar imageromanokun ( 2016-08-31 15:13:56 +0200 )edit
answered 2019-06-05 02:50:12 +0200
Windows 10. Disable Tools>Options>Libreoffice>Advanced >enable macro Recording
answered 2016-08-31 15:26:20 +0200
Ratslinger gravatar image
There have been numerous bugs reported concerning copy/paste in Windows. See answer, response, and bug report on this post (click here) where MS Edge was part of the problem. Personally no problems using Linux.
Thank you for response. Had a look at the link provided but as far as I remember in my case MS Edge still was not opened when it was not possible to paste new material into Writer, but I am not 100% sure. I tried to copy form Notepad, MS Edge, Google Chrome. In all the same cases it was not possible to paste it into Writer document, it put the previous material but as I already mentioned I am not 100% sure if MS Edge was closed. Normally I use Google Chrome
romanokun gravatar imageromanokun ( 2016-08-31 15:33:44 +0200 )edit
@romanokun In future please respond with comment. In the link, the problem was Edge. When it was closed, the copy/paste worked properly. One of the bug reports mentioned "other software may cause some of these problems ". Windows affects the clipboard in various ways now and the only way to fix some of the problems associated with LO is to report as a bug what specifically caused the problem. Not really a LO bug but a change in Windows requiring a change in LO.
Ratslinger gravatar imageRatslinger ( 2016-08-31 15:52:41 +0200 )edit
Anyway the problem should not be present even if MS Edge is opened, But for temp solution it might be OK. If it is really Ms Edge than it is some kind of relief to know what exactly causes a problem. Next time I will pay attention to if the MS Edge is opened if the same problem repeats. Thank you for response
romanokun gravatar imageromanokun ( 2016-08-31 15:53:36 +0200 )edit
Keep in mind in your case the problem may be when Chrome is open or possibly something else.
Ratslinger gravatar imageRatslinger ( 2016-08-31 16:06:12 +0200 )edit
If the problem is just that the second item in the clipboard queue is being pasted, instead of the last or top item, then a successful work-around might be to Copy everything twice before Pasting, so that the wanted item occupies both the top and second positions in the clipboard queue. Does that work?
ve3oat gravatar imageve3oat ( 2019-06-05 06:21:05 +0200 )edit
answered 2017-11-12 19:03:18 +0200
marvinscottiii gravatar image
I'm sorry, but I am not familiar with MS Edge.
It is Windows 10 browser. As stated in comments, "other software may cause some of these problems ".
Ratslinger gravatar imageRatslinger ( 2017-11-12 19:44:39 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2016-08-31 14:50:58 +0200
Seen: 8,887 times
Last updated: Jun 05 '19
