Hello. It seems that there is a bug in both last Still and Fresh version.
It is simple as that: sometimes when I try to paste something into Writer document it put the previous material from the clipboard, not the last one. So I need to save the document, close it, reopen it, put “Paste” and only in this case it will paste the correct last piece of the clipboard.
Annoying thing.
Has anyone encountered with the same problem? How to fix it?
To developers: please investigate into this and if it is a real bug than
Roman
