Calc: reference same cell number after insert row?
asked 2016-12-31 02:17:26 +0200
Nikolay Georgiev gravatar image
In an emtpy sheet, If A3=10, what value should A1 have, so that both of the following statements are true:
  1. A1 displays the value 10
  2. After inserting a new row between A1 and A3, A4 displays 10 and A1 displays the value of A3, which is currently empty.
What I already tested:
  • If A1=A3 or A1=A$3, statement 1 is correct, but statement 2 is incorrect, because after inserting a new row the value of A1 changes to A4 or A$4 respectively, and does not remain A3 or A$3 as desired.
Thank you!
1 Answer
1
answered 2016-12-31 07:00:21 +0200
pierre-yves samyn gravatar image
Hi
=INDIRECT("A3")
Regards
thank you! It works and it is exactly what I was looking for!
Nikolay Georgiev gravatar imageNikolay Georgiev ( 2016-12-31 15:46:36 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2016-12-31 02:17:26 +0200
Seen: 42 times
Last updated: Dec 31 '16
