1
Tools > Options > Memory and check 'Enable system tray Quickstarter' [closed]
asked 2012-12-05 13:29:38 +0100
Paddy Landau gravatar image
updated 2015-10-22 23:27:20 +0100
Alex Kemp gravatar image
I had Libre Office 3.6.0 (I think), and the Quickstarter worked perfectly.
I uninstalled it, and installed Libre Office 3.6.4.
Now, Quickstart does not work. If I start Libre Office with the following command:
libreoffice3.6 --quickstart
Libre Office starts normally, ignoring the Quickstart option.
There is no option Tools > Options > Memory > Enable system tray Quickstarter.
I cannot upload a screen-shot, but you can see it here:
https://www.dropbox.com/s/9mxjz96jih45qmt/LO%20memory%20options.png
I am using Linux Ubuntu 12.04 fully updated.
close date 2015-10-22 23:28:08.071731
@mariosv - Thank you for your answer. However, I think you missed the point that I do not have that option. I have added a screen-shot to my original post.
Paddy Landau gravatar imagePaddy Landau ( 2012-12-16 12:15:56 +0100 )edit
My question is a duplicate of this one - sadly I have had no answer either. Your screen-shot matches mine. I remember sometime ago that the option disappeared on Window build unless you selected a Custom build - or something similar.
I have searched high and low and cannot find any mention of this.
Oldbwl gravatar imageOldbwl ( 2013-01-03 21:07:22 +0100 )edit
Hi, I am running libreoffice 4.1.1 on a VM and have no gui. I only start it in headless mode. How can i set the memory options ??
uday gravatar imageuday ( 2013-10-17 15:10:20 +0100 )edit
1
answered 2013-02-21 20:13:15 +0100
TonyKl gravatar image
The option and checkbox under Tools/Options/Memory/LibreOffice Quickstarter won't exist if the option is not installed. On Windows you have to launch the MSI. Control Panel/Add/Remove programs/Change/Modify/+Optional Components.. find and enable the quickstarter option ( click dropdown and select "This feature will be installed on the hard drive.") I imagine/hope the ubuntu install/modify has a similar process.
I do not have the option in "Menu/Tools/Options/Memory/LibreOffice Quicstarter - Load LibreOffice during...." and is not visible in ANY section "Control Panel/Add/Remove programs/Change/Modify/+Optional Components" either. I REALLY want my quick launch back. Any other suggestions?
I'm using Version: 4.3.2.2 Build ID: edfb5295ba211bd31ad47d0bad0118690f76407d
TechKnowHermit gravatar imageTechKnowHermit ( 2014-10-10 00:10:54 +0100 )edit
1
answered 2012-12-05 22:43:06 +0100
m.a.riosv gravatar image
The option is now: Menu/Tools/Options/Memory/LibreOffice Quicstarter - Load LibreOffice during....
In case of Linux-based operating systems, just install libreoffice-systray
Ljiljan gravatar imageLjiljan ( 2017-02-05 07:59:27 +0100 )edit
answered 2012-12-16 17:31:31 +0100
ROSt52 gravatar image
I too have now 3.6.4 running and don't have that option neither. As I don't use this option, I did not recognize this earlier.
As far as I remember I saw a box to be checked in 3.5.7, which I used until a few days ago.
1 follower
Asked: 2012-12-05 13:29:38 +0100
Seen: 3,653 times
Last updated: Feb 21 '13
