2 problems - Infinate loop and deleting a "?"
2 - 3 times per day LOCALC goes into an infinate loop where I have to shut it down manually and reload?
I am trying to simlify E-mails like this:
https://www.canva.com/link?target=mailto%3Ajpbroheimer%40archomaha.org&design=DAFltXi5MTQ&accessRole=viewer&linkSource=document
Simplify to: jpbroheimer@achomaha.org
I do a CTR-M
Using FIND AND REPLACE, I can replace all but the “?”.
Any ideas ?
As always, Thanks a BUNCH,
⌡im [THE BookMan]
Check, if “regular expressions” is selected, because ? is a special character there. If you need regular expressions, search for \?
Otherwise switch it off.
You are correct … DUH!
Thank you,
⌡im [THE BookMan]
What is “LOCALC”? Your hard drive?
By the way: One problem, one topic. This topic is marked as solved, and there is another question here.
