Hi,
I am trying to add the formula for standard deviation to a column via macro.
Something like “= STDEV(A1:A2)”
I use R1C1.
If I use something like this: (Inside for loop)
oCell = Sheet.getCellByPosition(i,lastRow+1)
temp = "=STDEV(INDIRECT(" & Chr(34) & "R7C" & CStr(i) & Chr(34) & ",0):INDIRECT(" & Chr(34) & "R" & CStr(lastRow) & "C" & CStr(i) & Chr(34) & ",0)"
oCell.Formula = temp
The resulting formula in the cell is
=STDEV(INDIRECT("R7C4",0):INDIRECT("R59C4",0))
However the result is 508 (Pair Missing). If I delete a bracket in the cell that’s just been modified by the macro and hit enter, well it corrects it and works. the only thing is the formula is the same.
What’s going on?
