Windows 10 Latest
LO 7.2.0 and 7.2.1, Firebird embedded
Base table with about 370 records and 25 fields
Conversion from embedded HSQLDB was done a number of versions ago with no major problems.
Everything ran fine (as far as I can tell) through version 7.1.5.
Updated to 7.2.0 and now have problems with relatively simple queries that no longer run, or run super slow and return garbage entries and/or missing records. Mailmerge using queries experience the same thing.
A search of recent changes and bug reports does not bring up anything similar.
I am at a loss of even how to describe the problem or set up the failing conditions.
I am pretty sure (but not positive) that it is not a table problem since it has been running fine up to 7.2.
Was there by any chance a Firebird change in 7.2 ?
Anybody else experiencing Base query problem in 7.2 ?
Here is a test file and a picture of results. I went to Tables and opened Newpersonalinfo. Selected the Zip column and tried to sort A-Z. After a long time of appearing to be hung up, the result was a messed up sort.
