Hi,
Need help creating a macro that searches for specified text in a document and sets a specified cell background color if found.
Example: column K contains ambulance call totals, in some documents some totals may not exist, it’s always different, that’s the problem.
My macro is quite simple and clumsy, if it doesn’t find the right total it sets the background color of the cell of the previous found total.
Here is an example of my macro, it only has three totals, but in reality there are many more.
sub BColor
dim document as object
dim dispatcher as object
document = ThisComponent.CurrentController.Frame
dim color1Args(1) as new com.sun.star.beans.PropertyValue
color1Args(0).Name = "SearchItem.SearchString"
color1Args(0).Value = "Hospitalized"
color1Args(1).Name = "SearchItem.Command"
color1Args(1).Value = 1
dispatcher.executeDispatch(document, ".uno:ExecuteSearch", "", 0, color1Args())
dim colorBk1Args(0) as new com.sun.star.beans.PropertyValue
colorBk1Args(0).Name = "BackgroundColor"
colorBk1Args(0).Value = 16768601
dispatcher.executeDispatch(document, ".uno:BackgroundColor", "", 0, colorBk1Args())
dim color2Args(1) as new com.sun.star.beans.PropertyValue
color2Args(0).Name = "SearchItem.SearchString"
color2Args(0).Value = "NO ON THE PLACE"
color2Args(1).Name = "SearchItem.Command"
color2Args(1).Value = 1
dispatcher.executeDispatch(document, ".uno:ExecuteSearch", "", 0, color2Args())
dim colorBk2Args(0) as new com.sun.star.beans.PropertyValue
colorBk2Args(0).Name = "BackgroundColor"
colorBk2Args(0).Value = 15658734
dispatcher.executeDispatch(document, ".uno:BackgroundColor", "", 0, colorBk2Args())
dim color3Args(1) as new com.sun.star.beans.PropertyValue
color3Args(0).Name = "SearchItem.SearchString"
color3Args(0).Value = "Call canceled*"
color3Args(1).Name = "SearchItem.Command"
color3Args(1).Value = 1
dispatcher.executeDispatch(document, ".uno:ExecuteSearch", "", 0, color3Args())
dim colorBk3Args(0) as new com.sun.star.beans.PropertyValue
colorBk3Args(0).Name = "BackgroundColor"
colorBk3Args(0).Value = 16711680
dispatcher.executeDispatch(document, ".uno:BackgroundColor", "", 0, colorBk3Args())
end sub
Is it possible to make it so that if the desired total is not found, the background color of the cell is not applied and the macro continues to search for another total?
p.s.: I know about such function as Conditional Formatting, but the thing is that each time to create Conditions for new documents is very long, as far as I know the created Conditions are created for one document and they can not be transferred to other documents.
p.s.s: Sorry for the online translator, English is not my primary language, if something is not clear write about it and I will try to rephrase my question.
Thanks
