Dears, I have a problem with my setup, there are in my document, pipes in each new line. Below attachment about that. I need to remove that. Help me, please.
You appear to have Track Changes turned on - this might be from accidentally hitting the keyboard shortcut Shift + Ctr +C. And you also have Show Changes turned on.
You can disable Track Changes by using the same keyboard shortcut, or vi a the menu Edit | Track Changes and uncheck Record. In the same menu, disable Show.
You may also need to Accept All to manage the changes. For more information search the Help for changes
If this answer helped you, please accept it by clicking the check mark to the left and, karma permitting, upvote it. That will help other people with the same question.
In case you need clarification, edit your question (don’t use an answer) or comment the relevant answer.
Tks, i solved change edit>track changes> and click disable show.
