Vlookup function works very slowly on files with 100k or more lines. While ms-excel searches with verticallookup, it runs 4 processors. Therefore its more faster than Calc. I think there is an urgent need for improvement in this regard.
why tells this blog:
This work is available in LibreOffice 7.4,
as far I recall the binary search on sorted VLOOKUPs exist since Star-Office ?
Indeed. But if you read the blog, it talks about speeding up unsorted lookups, using pre-sorted data internally.
ah yes I got it, it sorts first virtually, and does binary Search on the virtual array…
I am using LibreOffice 7.3.4.2. I read thats article. I will try vlookup with 7.4 version. Thanks for information.
I will try with 7.4 version. Thanks for answers.
This office suite comes with a database component able to do millions of lookups in a second (depending on the actual type of database and proper indexing).
